David G
Tim,
The 4020 is scheduled to get rebuilt this winter. I think it would be prudent to go through the steering motor and the front pump. I am not comfortable doing this, Is this something you do?
Yes, I do them on a regular basis, when I re-seal a pump I replace the stroke valve and inspect the entire pump for wear, then put it on the test stand and set it and run it for a bit to check for leakage,the steer motor is not a bad job, I can walk you through it or if it's possible get it to me and I'll do it here,,while you watch if you want..
