Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: 70 -- knock revisited
11-23-2012 17:18:59
Well, the big nut is for setting the crankshaft end play only. But if the locktite has set up then its probably too late now. The two bolts with nuts are for tightening the flywheel to the crank.
Bob Harvey
11-23-2012 18:51:53
 Re: 70 -- knock revisited in reply to greenday, 11-23-2012 17:18:59
Locktite is just a temporary 'glue', it is NOT permanent. That is the point of it, Use it , it will ensure the bolt/nut will not move under normal circumstances. Put a wrench on a 'Loctited' item, and it may take a slightly larger effort to 'break it loose', but it is NOT permanent. HTH
