Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Almost....but not quite there on starting
dan_41jdh
11-23-2012 15:28:43
In the earlier thread, you said:
"What I"m seeing is that the clutch side cylinder has gasoline POURING out of the petcock".
And in that same thread you said:
"...when it first started, the smoke was black. It did not contune smoling. Subsequent attempts showed white smoke- which I thought indicated it was too lean."
And in this thread a few days ago (21 Nov) you said:
"I am getting good fuel and the mist from the petcocks. The plugs do get wet though, so it might be flooding out".
All of those symptoms are typical of flooding, and may indicate you have a leaking needle valve, or that the needle valve seat isn't tight and gas is leaking past the seat gasket.
You've mentioned that you've "..rebuilt the carb, and have checked it about half a dozen times", but have you positively verified that the needle and seat are sealing properly? If they're leaking, this could be the source of your problem. And you can easily check this with a couple of different tests - one that F-I-T mentioned earlier was to loosen your carburetor from the manifold and hold it away with some small spacers such as wire rods or nails. If you have a leaking needle and seat, you will eventually see gasoline leaking out of that space held open by the spacers, and that leaking gasoline will run into your cylinders and will eventually fill up your crankcase. The other test is to use a float level test manometer that you can make yourself out of hardware store parts to verify your float level is correct and stays constant at the 3/4" level. If tractor is not running and the level creeps up something is wrong with your needle and seat or its gasket since gasoline is obviously leaking into the bowl when it shouldn't.
Travis W
11-25-2012 19:19:55
 Re: Almost....but not quite there on starting in reply to dan_41jdh, 11-23-2012 15:28:43
DAN - YOU AND FIT ARE SPOT ON. I DIDN'T GET THE LEAK RIGHT AWAY, BUT SURE ENOUGH, THERE HAS TO BE SOME KIND OF PROBLEM WITH THE NEEDLE OR SEAT. HOW DO I GET THIS STRAIGHTENED OUT? DO I NEED TO MAKE MY OWN GASKET? ADVICE IS SINCERELY APPRECIATED.
dan_41jdh
11-26-2012 14:10:20
 Re: Almost....but not quite there on starting in reply to Travis W, 11-25-2012 19:19:55
Well, I'm a poor one to answer your questions because I've never worked on this specific carburetor. But the attached excerpt from the parts book shows a gasket between the needle valve seat and the carburetor bowl (item #34).
If it's anything like other needle valve seat gaskets, I wouldn't recommend trying to make one, but would buy one from one of the usual suppliers, such as Robert's Carburetor Repair. (Theirs lists for $0.57.)
However, before one assumes the gasket is the culprit, check the needle and seat itself to ensure they seal properly - and check to ensure the carburetor bowl is not cracked or has some deficiency that might let fuel pass through from the needle zone into the bowl itself. There can be lots of nasty little gremlins that might be the cause of fuel overflowing the bowl, and only a keen eye and a detective's mindset can find them.
Good luck!
