Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Help: need 13x28 rim for Uncle's 2010
11-23-2012 12:18:27
Favorite uncle has a 1965 2010 with rusted out rear rim. I"ve seen no photo, but the description is that it is a one piece wheel; pressed steel center with factory welded-on rim, (??). It has a 14.9x28 tire on, "13x28," wheel. Nine lug- 7.5 inch center. Four slots at rim.
Can anyone help by suggesting where to find a wheel/rim? Thanks, Dennis (ex-JD Model D collector)
Tx Jim
11-23-2012 12:45:55
 Re: Help: need 13x28 rim for Uncle's 2010 in reply to DennisT, 11-23-2012 12:18:27
I'd suggest checking with a tractor salvage yard.
JD3016 RIM 1 (13.6 X 28" TIRES AND 14.9 X 28" TIRES) (SUB FOR JD3010)
11-23-2012 13:01:33
 Re: Help: need 13x28 rim for Uncle's 2010 in reply to Tx Jim, 11-23-2012 12:45:55
Thanks for the correct part number. I wonder if this is the only possible number or it or if JD had numerous optional wheels that year and model???
We are chasing salvage yards. So far the only used one we found is out-of-state and over $200 plus shipping.
Side note is that I'm trying to help and the tractor and my uncle are 300 miles from here. Hence, no photo at this point. Tractor is in Western Washington state.
This tractor also needs some help just inside the PTO shaft. Shaft seems OK, but there must be a seized or bad bearing or a broken piece there too.
No end to these things.......
Tx Jim
11-24-2012 04:12:39
 Re: Help: need 13x28 rim for Uncle's 2010 in reply to DennisT, 11-23-2012 13:01:33
Did you see the part sub number JD3010 at the end of the parts description? You possibly could find a wheel from axle mount duals. The fact the wheel is "9" bolt is going to make it more scarce
11-24-2012 08:56:56
 Re: Help: need 13x28 rim for Uncle's 2010 in reply to Tx Jim, 11-24-2012 04:12:39
Thanks for the tip about rims from duals. Between this problem, the PTO problem and the SynchroRange transmissions in this model, they seem to be a head ache. I will say he's never had trouble with the transmission.
