Air Ride Seat on 20 Series
2510Paul
Has anyone put an air ride seat in a 4320, 4020, 2520, etc. tractor? If so where did you get it and how did the installation go? My 4320 also has a factory cab with ROPS. Paul
Like every 'non stock' addition , it will require some simple fabrication of mounting brackets and (if req'd) air lines. I know NOTHING about your tractor, BUT, most of this type of work needs some thinking and the ability to create stuff. HTH
The air ride seat conversion for a 4430 might be made to work.
AH136929 COMPRESSOR KIT, ASSY KIT ADD 518.70 USD
AH136930 VALVE KIT, HT ADJ SWITCH/VALVE KIT ADD 84.09 USD
