Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: Almost....but not quite there on starting
Rustys Restos
11-23-2012 08:26:29
Have you tried to pull start it?If it pull starts, put 1/2 turn more on the impulse sping and try again, it worked for me.Mae certain points are clean and set to 15 thousandths.set both carb needles to 1 1/4 turns for clean carb,may need a little more idle for dirty carb.Buy new plugs and gap them to 20 the drain on the fuel bowl and let some run into a cup does it look clean?Close the choke,set the throttle so the stop on the throttle shaft is just off the spring.roll it ver one time and move the choke to 1/2 and roll it again If you have checked/set these items it will start.
