Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: 2240 JD hydraulic
Resting Relics 1
11-22-2012 07:42:35
Hey Robin, As DEEREMEYER1 says you have a high pressure leak internally somewhere that is causing the main pump to try and overcome the leak which in turn makes the oil get hot fast. This is not unheard of in closed center hydraulic systems, but the trick is to find out where the leak is. I would do as the guys have mentioned here and start isolating things starting with the loader valve as that's probably the easiest. My guess is that it's probably in the steering valve because the loader valve and steering are not connected per-say. The way you describe it all your hydraulic stuff should also be hot if you were using them because all the hydraulic oil must be hot but you only notice the steering and the loader valve because that's where your sitting and that's what your using. It is also a fairly common problem with steering valves on these tractors especially with loaders no them. If that's the problem a repacking will be needed. Good Luck! John
Tx Jim
11-22-2012 09:44:58
 Re: 2240 JD hydraulic in reply to Resting Relics 1, 11-22-2012 07:42:35
John
I'm not trying to start a fight BUT normally the hyd function that is leaking internally on a closed-center hyd system will be hotter than the rest of the hyd components. Both the components that Robin mentioned that are exhibiting heat are the easiest components to check for internal leakage.
Copyright © 1997-2015 Yesterday's Tractor Co.
