Yesterday's Tractor Co. Compare our Prices For Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: 2640 no hydraulics
[Return to Forum]
Jcrank01
11-21-2012 18:07:58
166.205.55.29
I just purchased a 2640 with a 146 loader today. The hydraulics aren't working and my mechanic told me it was the transmission hydraulic pump. It has the high/low and it won't pull itself. I was told that It all quit at one time. I didn't pay much for it so I will part it out if it cost too much to fix. Any ideas on what else could be wrong. Thanks and happy thanksgiving
[Reply]   [No Email]
Cliff Nelson
11-23-2012 21:26:39
96.60.120.179
 Re: 2640 no hydraulics in reply to Jcrank01, 11-21-2012 18:07:58
Look in the inspection cover on the left side of the clutch housing and see if the clutch hub that drives the live power/trans pump is bad. If not that it is inside the trans as stated before.
[Reply]  [No Email]
Tim S
11-22-2012 11:12:53
75.60.207.71
Your mechanic is correct, you have no transmission oil pressure, you can play around with out side stuff,,,but you will end up splitting it near the shifters, could be pump failure, broken oil pipe, or a failed component...
[Reply]  [No Email]
Jcrank01
11-22-2012 10:07:32
166.205.55.25
I apologize I should've added more detail. Nothing at all works, no steering, no loader, no lift, and no pto now that I've checked that as well. It would pull itself a little on level ground but not uphill at all. Once it started slipping I just put it in neutral and towed it. It's on my trailer now with the loader down. Someone told me to take the hood off and fill the front hyd resiviour with oil and see if anything would work. That would rule out the front pump being bad? Correct or not?
[Reply]  [No Email]
Tx Jim
11-22-2012 10:18:45
67.142.163.27
 Re: 2640 no hydraulics in reply to Jcrank01, 11-22-2012 10:07:32
IMHO the frt hyd reservoir won't hold enough oil for hyd's to function very long if at all.
[Reply]  [No Email]
Resting Relics 1
11-22-2012 07:25:01
75.24.77.128
Hey,
You say it has no hydraulics but then you go on to say no Hi-Low. Does no hydraulics mean no steering, no loader no three point hitch, etc. If so the hi-low not working is probably because there is no charge pressure, which powers the hi-low and the pto clutches and then goes on also to feed the main pump. There are many reasons that the transmission pump may not be working from low oil to broken steel lines, to a broken drive part. We need more info in order to guide you where to start. Good Luck!
John
[Reply]  [No Email]
Jcrank01
11-22-2012 06:24:05
166.205.55.19
Switching the hi/lo has no effect on it. I will try the pto next time I'm near the tractor
[Reply]  [No Email]
Tx Jim
11-22-2012 04:26:00
67.142.163.26
Is your mechanic "knowledgeable" on closed center hyds? Several components besides the trans pump can affect correct operation.
I agree with b&d on needing to check both psi's. Does changing from high to low(vice-verse) of the hyd hi-lo affect hyd operation any? Same thing with pto if it has hyd ind pto? The supply tubes for both hyd hi-lo & pto have a history of leakage problems. How is loader controlled,by scv or ind valve?? If ind valve remove return hose,start tractor and see that no oil flows out hose.
[Reply]  [No Email]
buickanddeere
11-21-2012 20:04:29
216.183.136.242
Measure trans oil level.
Inspect and change/clean trans filter and trans screen.
Measure trans oil pressure at high/low and pto ports
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
