| John Deere Tractors Discussion Forum |
Topic: 2240 JD hydraulic
[Return to Forum]
| Author |
[Modern View]
| Robin Babb
11-21-2012 17:49:57
74.248.232.228
I have a 2240 JD tractor with frontend loader, and the control valve and steering column get to hot to touch after running only a few minutes. |
| Resting Relics 1
11-22-2012 07:42:35
75.24.77.128
Re: 2240 JD hydraulic in reply to Robin Babb, 11-21-2012 17:49:57
| Hey Robin, As DEEREMEYER1 says you have a high pressure leak internally somewhere that is causing the main pump to try and overcome the leak which in turn makes the oil get hot fast. This is not unheard of in closed center hydraulic systems, but the trick is to find out where the leak is. I would do as the guys have mentioned here and start isolating things starting with the loader valve as that's probably the easiest. My guess is that it's probably in the steering valve because the loader valve and steering are not connected per-say. The way you describe it all your hydraulic stuff should also be hot if you were using them because all the hydraulic oil must be hot but you only notice the steering and the loader valve because that's where your sitting and that's what your using. It is also a fairly common problem with steering valves on these tractors especially with loaders no them. If that's the problem a repacking will be needed. Good Luck! John |
| Tx Jim
11-22-2012 09:44:58
67.142.163.22
Re: 2240 JD hydraulic in reply to Resting Relics 1, 11-22-2012 07:42:35
| Quoting Removed, click Modern View to see
John
I'm not trying to start a fight BUT normally the hyd function that is leaking internally on a closed-center hyd system will be hotter than the rest of the hyd components. Both the components that Robin mentioned that are exhibiting heat are the easiest components to check for internal leakage. |
| Tx Jim
11-22-2012 04:38:40
67.142.163.26
2 easy diagnostic steps are to isolate steering and loader valve. Remove steering supply line and cap fitting and see if heat goes away. Disconnect loader valve return line and with both spools in neutral see if any oil comes out return hose(none should) with engine running. |
| buickanddeere
11-21-2012 20:02:26
216.183.136.242
| What kind of loader control valve? How is the valve plumbed into the tractor? Is the problem sudden, always existed or has gradually developed? |
| DEEREMEYER1
11-21-2012 18:06:29
71.50.25.139
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
