TractorLinks.com
Show Parts for Model:
Re: More 4230 Questions
Tim S
11-21-2012 15:14:38
There is a bushing at the rear of the hi/low pack, but if you rotate the shaft it will line up. i have a 4440 Quad that I just brought in with a bad noise as it pulls going forward, on the coast it goes away,,I'm thinking the bottom shaft rear bearing, I'm going in from the back on it, pulling the cab, final drives then setting the transmission off .,On the 4440 power shift I have in here it was slipping in all the gears, the pressures were near right so I went in from the front, the dry clutch is bad...I'm gonna pull the C1&2 clutch packs out and inspect them and the trans. pump while I'm in there...
