I have a 2030 that smokes very bad blue smoke on a
cold start, once it warms up still smokes but not
near as bad, If you plug in the block heater, it
doesn"t smoke too bad. Two injectors tested as
marginal, two were good, I didn"t replace them yet.
I put valve seals in, didn"t change it. Breather has
quite a bit of blow by. I haven"t used it enough to
know if it uses much oil. Looks as though the pump
has been rebuilt. About 5000 hrs. Is it time for a
overhaul or does anyone have any ideas to try?
