Yesterday's Tractor Co. Fast, Friendly Parts Service
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: More 4230 Questions
[Return to Forum]
greenmachine
11-21-2012 09:47:36
98.213.132.112
Looked on JDparts, cant see where the trans pump shaft is driven off of. Is their a bushing on both ends? Pulled the cover off the top of the trans, everything looks good..Started it, let it get warm,o strange noises from that area. I am starting to think its somewhere in the clutch housing. Tractor also seems to have more vibration that normal.Engine was overhauled this summer with a new crank pulley. I did an inframe, so I didnt look at the clutch.Is it possible to have a vibration at that end.. Either way between the rattle and the vibration something is wrong..Have to start somewhere. Any help would be appreciated. Thanks!
Joe
[Reply]   [No Email]
Greenmachine
11-21-2012 16:03:16
174.238.195.71
Re: More 4230 Questions in reply to greenmachine, 11-21-2012 09:47:36
Upon a second look at the trams pump shaft it is bent not sure how that could happen. Figuring that might be my noise. Ordered new shaft and pump today start there with the easy stuff. Next it will get split. Thanks
  [Reply]  [No Email]
Tim S
11-21-2012 11:33:54
75.60.207.71
You will get a lot of strange noise with the cover off,so don"t let that lead you astray, the trans pump drives off a plug seated in the back of the crank shaft, rarely is there any trouble on that end.
  [Reply]  [No Email]
greenmachine
11-21-2012 13:44:55
98.213.132.112
Re: More 4230 Questions in reply to Tim S, 11-21-2012 11:33:54
The only reason I ask is,the shaft pulled out very easy, went in easy. I decided to pull it back out some to spin the pump by hand to feel for any play. Anyways, I could not get the shaft back through the pump,it got hung up,is their a bushing on the other end? Regardless I am going to have to split it to figure out where this noise is coming from..I know its not in the trans,so maybe I should start with a split at the clutch? Thanks for all your help, if you were closer I would pay you to do it. Thanks!
Joe
  [Reply]  [No Email]
Tim S
11-21-2012 15:14:38
75.60.207.71
Re: More 4230 Questions in reply to greenmachine, 11-21-2012 13:44:55
There is a bushing at the rear of the hi/low pack, but if you rotate the shaft it will line up. i have a 4440 Quad that I just brought in with a bad noise as it pulls going forward, on the coast it goes away,,I'm thinking the bottom shaft rear bearing, I'm going in from the back on it, pulling the cab, final drives then setting the transmission off .,On the 4440 power shift I have in here it was slipping in all the gears, the pressures were near right so I went in from the front, the dry clutch is bad...I'm gonna pull the C1&2 clutch packs out and inspect them and the trans. pump while I'm in there...
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
