TractorLinks.com
Show Parts for Model:
Re: john deere M ignition problem
M-MAN
11-20-2012 22:13:37
My guess is when you tightned the nut holding the condensor wire you let it move and the points spring got pushed down to where it is touching. It has to stay straight.
Lets do this over. Better NAPA or Deere points. Gap at 19. Dist terminal will be at about 5 looking straight on. Dist posts will be about 5 minutes till three. Front post to front plug. Fire her up and put a timing light on front plug wire. Should see SPARK centered in the window at full throttle. At idle it should drop back to TC (close). If it doesn't drop back when the speed drops the advance is stuck.
John is correct about the dist. The only way to get it 180 out is to drop the oil pump or change the drive lug on the bottom of the dist.
farkle
11-23-2012 14:11:48
 Re: john deere M ignition problem in reply to M-MAN, 11-20-2012 22:13:37
Thanks guys, had a little time today to mess with it. You were right about the spring and condenser wires shorting out,( due to a cracked insulator). so I got the sparking on the shaft fixed. now with the cap off I can not get a consistent spark out of points when cranking it over.I get a few weak sparks then quits. when I install cap, im getting a unconsistent spark on the plugs and will not fire when trying to start it. could it be the coil ? thanks.
