Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: 4230 Hyd. Pump?
buickanddeere
11-20-2012 08:56:17
Before ripping the tractor apart and spending $. Why not use a pressure gauge on various ports and find out what is happening?
DEEREMEYER1
11-21-2012 18:17:56
 Re: 4230 Hyd. Pump? in reply to buickanddeere, 11-20-2012 08:56:17
You don't have to "rip the tractor apart" to pull the pump driveshaft. Remove the third link bracket, remove the plug underneath and slide it out. Worn off hex on the pump shaft is a common deal with Quad-Ranges, and he wasn't wrong to check it. Setting up to check transmission pump flow takes considerably more work than pulling the driveshaft.
buickanddeere
11-21-2012 20:09:18
 Re: 4230 Hyd. Pump? in reply to DEEREMEYER1, 11-21-2012 18:17:56
May as well throw out those test gauges and just stock up on pump drive shafts.
