Yesterday's Tractor Co. Restoration Quality Tractor Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: john deere M ignition problem
[Return to Forum]
farkle
11-20-2012 08:12:49
173.189.65.189
Was having trouble with only running on one cylinder, changed plugs and points. now is backfiring out exhaust blowing fire and sparks and seems extremely hot. when checking the points for spark I noticed its also sparking where the distributor shaft runs on points to open and close them. (its jumping past the little nylon bushing that its supposed to ride on ).any advice would be appreciated.
[Reply]   [No Email]
M-MAN
11-20-2012 22:13:37
184.39.65.180
Re: john deere M ignition problem in reply to farkle, 11-20-2012 08:12:49
My guess is when you tightned the nut holding the condensor wire you let it move and the points spring got pushed down to where it is touching. It has to stay straight.
Lets do this over. Better NAPA or Deere points. Gap at 19. Dist terminal will be at about 5 looking straight on. Dist posts will be about 5 minutes till three. Front post to front plug. Fire her up and put a timing light on front plug wire. Should see SPARK centered in the window at full throttle. At idle it should drop back to TC (close). If it doesn't drop back when the speed drops the advance is stuck.
John is correct about the dist. The only way to get it 180 out is to drop the oil pump or change the drive lug on the bottom of the dist.
  [Reply]  [No Email]
farkle
11-23-2012 14:11:48
69.40.132.212
Re: john deere M ignition problem in reply to M-MAN, 11-20-2012 22:13:37
Thanks guys, had a little time today to mess with it. You were right about the spring and condenser wires shorting out,( due to a cracked insulator). so I got the sparking on the shaft fixed. now with the cap off I can not get a consistent spark out of points when cranking it over.I get a few weak sparks then quits. when I install cap, im getting a unconsistent spark on the plugs and will not fire when trying to start it. could it be the coil ? thanks.
  [Reply]  [No Email]
lfnel
11-20-2012 15:31:02
173.27.205.97
Perhaps I'm leaving only breadcrumbs that might lead to nowhere, but it seems to me that the distributor "T" drive can be inserted 180 degrees from where it should be in the drive out of the top of the oil pump shaft. Then too, some M & MT distributors have four breaker point opening lobes on the shaft, some have two. Could either of these anomalies be figuring into the fun you're having?
  [Reply]  [No Email]
John T
11-20-2012 16:36:59
216.249.82.117
Re: john deere M ignition problem in reply to lfnel, 11-20-2012 15:31:02
Dubuques are NOT my cup o tea so NO WARRANTY but I think those drives have an offset so its impossible to install them 180 out WHERES M MAN WHEN WE NEED HIM
John T
  [Reply]  [No Email]
rla
11-21-2012 06:20:03
162.39.22.109
Re: john deere M ignition problem in reply to John T, 11-20-2012 16:36:59
John Is correct, you can't get them 180° off.
  [Reply]  [No Email]
John T
11-20-2012 09:18:55
216.249.82.117
Sometimes the spring on the points is shorting, the normal current path TO GROUND is from the wiring terminal where the condensor and the wire from coil (via the distributors side pass thru insulated bushing) is attached, then when points are closed to the distributor case/frame ground. Make sure all the little wires from condensor,,,,,,,to coil via pass thru,,,,are good and not shorted, then be sure when the points are open THERES NO TO GROUND PATH from the little wiring terminal. Both the coil wire and condensor are only grounded out when the points are closed. The condensor, to straight DC, should show an open circuit to ground ya know otherise its bad/shorted out.
With IGN ON, put a DC test lamp on the coils output (or where dist side terminal is) and with engine slowly turned over, it should be ON when points are open but OFF when closed
As already posted the cap and rotor tip needs to be in correct time with the cap so when the coil fires the tip is lined up with the correct cap pickup/terminal. The coils fires when the points break open and at that time the rotor tip needs to be lined up with the right cap pickup.
John T
  [Reply]  [No Email]
rla
11-20-2012 08:37:57
162.39.22.109
Is number one plug wire on Number one Plug &
is the wire in number one position on the cap?
  [Reply]  [No Email]
farkle
11-20-2012 08:48:08
173.189.65.189
Re: john deere M ignition problem in reply to rla, 11-20-2012 08:37:57
I will double check but i have it like it shows in manual.thanks
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
