Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
4230 Hyd. Pump?
greenmachine
11-20-2012 06:16:28
My 4230 has developed a noise in the rear. I changed the hydraulic fluid, filter, screen in the spring when I did axle bearings and seals.. Screen was completely clean, fluid was clean, opened filter it was clean. Brakes were perfect on both sides. I have used it about 150 hours since. When it gets hot, hydraulic oil that is, I get a rattle/knocking noise from under my feet/seat. It doesnt matter if the clutch is pushed in/ or in gear. This is a quad range. It shifts fine, works in all gears. Hydraulics seem fine, steering okay, 3pt up and down fine, although it does settle after an 1hr or so, but has done that along time. I decided to pull the shaft for the trans pump. It does has a touch of wear, but nothing I would consider terrible. Is it possible for the pump to rattle when the fluid gets hot. I looked on JDparts.com and didnt really see anything in the pump like a bushing that would do that. The noise does change when I used hydraulic functions, gets quiet when I lift up and implement. That is why I am leaning towards a new pump and shaft. But on the flip side dont want to waste my time. One other strange thing that has developed now that is is cooler at night. The pto will run for about 45-
60 seconds when I first start it. I check the linkage and it is returned all the way, and nothing is stuck under the rod. I bought this tractor new and was planning on keeping it around for misc use. But its starting to become a pita. Thanks for any insight.
Joe
Heat Houser
11-20-2012 14:20:33
 Re: 4230 Hyd. Pump? in reply to greenmachine, 11-20-2012 06:16:28
Had a noise in my 4010. Kinda a sharp rap/knock...went away when lifting the loader...worse at higher RPMs....worse when hot.
Traced it to the Hyd pump....thinking a delivery valve...pulled the pump down and everything looked good, resealed. Noticed the coupler "tightening bolts" (on the split, for the splines) were loose when removing the pump. Reinstalled the pump, tightened them.
No noise.....
The only thing I had changed was to tighten the coupling bolts so the splines in the coupler clamped on the pump shaft.
Removed, resealed the pump for nothing...Oh well.
Tx Jim
11-20-2012 09:27:58
 Re: 4230 Hyd. Pump? in reply to Old Popper, 11-20-2012 06:16:28
thulow
Junction block(parts key #24A/24B) is all my "CRS" will come up with. Pressure control valve(parts key #6) could also be at fault.
buickanddeere
11-20-2012 08:56:17
Before ripping the tractor apart and spending $. Why not use a pressure gauge on various ports and find out what is happening?
DEEREMEYER1
11-21-2012 18:17:56
 Re: 4230 Hyd. Pump? in reply to buickanddeere, 11-20-2012 08:56:17
You don't have to "rip the tractor apart" to pull the pump driveshaft. Remove the third link bracket, remove the plug underneath and slide it out. Worn off hex on the pump shaft is a common deal with Quad-Ranges, and he wasn't wrong to check it. Setting up to check transmission pump flow takes considerably more work than pulling the driveshaft.
buickanddeere
11-21-2012 20:09:18
 Re: 4230 Hyd. Pump? in reply to DEEREMEYER1, 11-21-2012 18:17:56
May as well throw out those test gauges and just stock up on pump drive shafts.
thurlow
11-20-2012 08:00:43
Noise.........don't know if 4230s are the same, but on 4430s, there's a 'block' (about 2 inches square) on the right side in rear of the battery where 2 or 3 hydraulic lines come together; if the bolt holding it to the tractor fails, it will vibrate and make a noise somewhat as you've described. I disremember the name of the thing (CRS), but Tim or Jim will know.............
Tim S
11-20-2012 10:16:33
 Re: 4230 Hyd. Pump? in reply to thurlow, 11-20-2012 08:00:43
Yes the 4230 has that block, it is where the oil pressure goes up to the attenuator and on into the cab it is a junction block, and yes that bolt holding it to the trans case is often broke.
Tim S
11-20-2012 07:23:33
How many hours are on it?, The trans. pump is most likely worn if it"s original. I would start there, the replacement pump is a larger,better pump, about $850,,if it is worn it would take a moment or so to pick up oil and pressure up the operating valve, which would mean it would also take a moment or 2 for the PTO brake to take hold, this could be the reason for the PTO to run for a bit then stop.
greenmachine
11-20-2012 08:56:10
 Re: 4230 Hyd. Pump? in reply to Tim S, 11-20-2012 07:23:33
5000 hours. Okay that would make sense.. Well maybe I will just do it and see what happens.. Not a lot of money. Thanks!
