Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
hydraulic pump seals
Iowa Chris
11-20-2012 04:33:36
I"ve got a 52 MT and the hydraulic pump leaks badly at the point where it bolts to the engine, my IT manual shows a shaft seal here so I"m assuming it has failed. Can anyone tell me what type of seal I should purchase and a source. Thanks.
Resting Relics 1
11-20-2012 05:11:41
 Re: hydraulic pump seals in reply to Iowa Chris, 11-20-2012 04:33:36
Chris, Its worth a shot to try a seal but be prepared for it to more of a problem than that. Very often these old pumps are scored internally after all these years and it causes pressure to escape out through the drive shaft. You may need a new pump. Good Luck! John
F-I-T
11-20-2012 04:45:13
 Re: hydraulic pump seals in reply to Tx Jim, 11-20-2012 04:33:36
Why not Deere? AM586T, Seal, Oil, is around $15.00
M-MAN
11-20-2012 07:16:55
 Re: hydraulic pump seals in reply to F-I-T, 11-20-2012 04:45:13
Along with the seal you will need the gasket set. #AM1149T Looking on the bright side, if that gasket hadn't failed when the seal went the TOM oil would be in the engine.
