TractorLinks.com
Show Parts for Model:
2755 temp gauge
Green Gobblin
11-19-2012 16:26:07
Temp gauge quite working and will not register at all. Even when the key is turned on and off the needle doesn't move. How do i test it and the sender? Also where do i find the sender? Thanks in advance
Tx Jim
11-20-2012 03:58:22
 Re: 2755 temp gauge in reply to Greenday, 11-19-2012 16:26:07
Parts key #1 RE51774 SENSOR,WATER TEMPERATURE ADD 36.76 USD
MSM
11-19-2012 17:21:32
 Re: 2755 temp gauge in reply to Green Gobblin, 11-19-2012 16:26:07
Sender is on the rear top of the head, you may be able to get to it with the hood on to test. If you take a jumper wire and turn the key on and hook one end to the sender wire and the other end to a good ground the guage should go to it's highest reading.If the guage doesn't move, it is faulty, if the guage goes up,the sender is faulty. Only other thing it could be is the connections in the dash itself are bad,but if the other guages work, it is more than likely the sender.
