Yesterday's Tractor Co. Restoration Quality Tractor Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: jd 70 rings
[Return to Forum]
jdman(mo)
11-17-2012 07:45:18
64.49.150.124
anyone know of a source for standard rings for a 70 gas that is not chrome. I have always thought that chrome rings will not seat well unless you bore. Russ
[Reply]   [No Email]
teddy52food
11-17-2012 10:11:46
184.94.175.179
 Re: jd 70 rings in reply to jdman(mo), 11-17-2012 07:45:18
Contact Dave Reed at the Otto Gas Engine Works.
[Reply]  [No Email]
buickanddeere
11-17-2012 09:21:34
184.151.63.247
Round rings mounted on worn piston grooves and ran in egg shaped bores . Tend to be less likely to seal.
[Reply]  [No Email]
Earl-IL
11-17-2012 09:08:13
50.81.209.158
Proper honing with a good crosshatch is important to good ring seating. Most people hone them too smooth. I always use the chrome ring & never had a problem. The rings that are manufactured today like Hastings or Sealed Power ,Perfect Circle they are prelapped for easy seating & less ring wear. Call Hastings they will tell you what grit stone to use on honing your block. What are you going to do about the ring ridge in the cylinders? Have you had the cyl measured? How much wear ? How much wear is in the top ring land on your pistons? What are you going to do with the tractor after the overhaul?
[Reply]  [No Email]
jdman(mo)
11-17-2012 14:22:55
64.49.150.124
 Re: jd 70 rings in reply to Earl-IL, 11-17-2012 09:08:13
Well there is very little ridge, but when I drop an old ring in the cylinder I have about 200 thousand. That is about 10 times what it should be. That is figuring .004 per inch of bore or about .024. I know what I should do, New pistons and .045 boring. The tractor will probably go to auction, and I expect to lose quite a bit of money. Even with my free labor.
[Reply]  [No Email]
JDG
11-17-2012 18:18:48
71.62.30.30
 Re: jd 70 rings in reply to jdman(mo), 11-17-2012 14:22:55
That will probably be the 70 at the auction with a new paint job and complete engine overhaul.
[Reply]  [No Email]
jdman(mo)
11-17-2012 18:51:47
64.49.150.124
 Re: jd 70 rings in reply to JDG, 11-17-2012 18:18:48
It was supposed to be recently overhauled before I bought it. Then the previous owner got water in the gas tank, destroying carb and piston locked up. Most auctioneers call anything repainted restored. My tractors are repaired and repainted not restored. Russ
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
