Can somebody help me out? I've got a 1020 gas tractor that leaks hydraulic oil out of the bottom of the bell housing when i shut it off. I believe it's the seal on the transmission input shaft. I need the tractor and want to do a one day job,so I want the parts here before I split it.
Problem is that the JD PArts website is a little vague on this. I pulled up the powertrain section,then number 10 clutch disconnect and flywheel. As far as I can tell,I need number 8,part number AF1934R. Does that look right? What about number 9,part number T22178 ? It says washer. Is that a large O ring/gasket for the housing that holds the seal?
Also,it looks like that seal goes in from the back. Does that number 10 part that they call a support have to come out?
Thanks.
Thanks.
