| Author |
[Modern View]
| Christos
11-15-2012 10:30:28
130.108.1.56
I realize I'm probably opening a can of worms but I was at the JD dealer getting some hardware and I saw a 2010 Gas Row Crop ROM with a loader. I bought a service manual for a 1010 and understand that both tractors use that weird sleeve and deck engine. Why were these tractors so bad? I've seen you all mention that the hydraulics are weird and the engine and there is poor parts support. Probably not going to buy it as I'd prefer to have a MF 165 or Ford 4000, but what was was wrong with these things? Christos |
| noshow
11-21-2012 07:55:56
192.149.244.9
2010 in reply to Christos, 11-15-2012 10:30:28
| I have to freshen mine up this winter as it is using to much oil these days. it still fires right off and purrs like a kitten and handles what I throw at it. allmost 8500 hrs and still a little tank |
| Tom in Mo.
11-18-2012 16:16:59
75.129.166.207
Re: 2010 in reply to Christos, 11-15-2012 10:30:28
| I've said this several times before whenever this topic comes up. My 2010 is a good, reliable machine. It starts evertime, has strong three point and remote hydraulics. I believe any 2010 made after serial number 42000 is probably a good machine. Before 42000 the engineers were very busy. |
| Tx Jim
11-21-2012 12:54:03
67.142.163.21
Re: 2010 in reply to Tom in Mo., 11-18-2012 16:16:59
| Quoting Removed, click Modern View to see
That relates to an old saying "you can't break a good 2010 and you can't repair a BAD 2010" :wink: |
| F-I-T
11-21-2012 10:54:51
184.6.247.3
Not knowing anything in particular about these models, I was wondering if there was a similar serial number break where improvements were made on the 1010? |
| buickanddeere
11-21-2012 12:08:04
184.151.63.226
Re: 2010 in reply to F-I-T, 11-21-2012 10:54:51
| Any gasser 1010 is fine. The transmission and etc were beefed up at serial # 31,001 . Another update at 42,001 updated the hydraulics. I wouldn't mind a gasser 1010 with 540/1000 . Install the diesel deck plate and a custom set of gas pistons. A few other tweaks and annoy the IH pullers with H's. |
| noshow
11-30-2012 07:48:36
192.149.244.9
Re: 2010 in reply to buickanddeere, 11-21-2012 12:08:04
Isnt the 1010 diesel the same deck plate as the 2010 gas? |
| F-I-T
11-21-2012 14:58:02
184.6.247.3
I ask because there is a decent looking 1010 down the road from me sitting behind a local car repair shop. Thought I might inquire about it, though I really don't need one. |
| Tx Jim
11-17-2012 04:20:39
67.142.163.27
Re: 2010 in reply to JON BARTON, 11-15-2012 10:30:28
2 different factories with different engineers. Similar with the Waterloo(hand clutch 2 cyl's) and the Dubuque(foot clutch 2 cyl's) |
| Tim S
11-17-2012 07:30:20
68.75.26.168
Re: 2010 in reply to Tx Jim, 11-17-2012 04:20:39
| "they are a pretty useful tractor if you can find a good one and keep it running." That"s like saying my dog would be a great hunter if he had more than 3 legs and wasn't blind.... |
| FarmerZeb
11-17-2012 20:42:11
198.153.82.61
Re: 2010 in reply to Tim S, 11-17-2012 07:30:20
| not exactly ... i have a decent one that runs .... its no 3010 or a 4010 but not useless |
| jddave
11-16-2012 17:54:15
67.84.193.100
| I hate to hear about John Deere failures. Gives one pause because, engineering-wise, why didn't they just make smaller versions of the 3010 and 4010 with all the good stuff for the 1010 and 2010? |
| DONALD ANGSTADT
11-16-2012 10:24:26
72.25.10.29
| SIR The 2010 was a unique tractor and a quote from a now deceased j.d. dealer was that if the J.D. co. would have made all there tractors like the 2010 they would now be out of business. From a mechanics view point I did not like the five compartment trans, the reason that there was such a loud trans. noise. The dry overcent multi disk pto clutch was very poor and very difficult to repair you had to remove the rockshaft. The hyd. system was open center with a full flow filter was ok but the gear pump was in the center of the tractor. Gear shift linkage had many more wear points as compared to the 3010, 4010. I swore I would never own one in my collection, but I changed my mind when I could locate 2010 diesel fork lift. I guess I will never learn Good luck |
| Tim S
11-16-2012 11:06:23
75.49.2.215
Re: 2010 in reply to DONALD ANGSTADT, 11-16-2012 10:24:26
| Very nicely put Don...it"s hard to find anything nice to say about a 2010, they were indeed a Mechanical Nite Mare... |
| FarmerZeb
11-15-2012 17:25:38
76.92.148.33
| | you can't really point to just one thing. they are a pretty useful tractor if you can find a good one and keep it running. i have one i use as a utility with a loader for misc stuff (lifting, logging, splitting firewood, back blading). I do not use it for anything that requires a load be put on on it. problems i have had with mine: transmission high range synchros continual carb adjustments for the weather eats points on an irregular basis hyd screen filter plugs up now an then |
| mkjd430
11-16-2012 04:50:49
99.103.129.178
Re: 2010 in reply to FarmerZeb, 11-15-2012 17:25:38
| when they work right they do have power and good lift on the loaders |
| Leroy
11-15-2012 17:23:41
69.88.205.38
| Those gas engines were used in the 40 & 45 combines for years with no problems. |
| schultz47
11-15-2012 16:37:45
184.176.221.33
| I farmed with a 2010 from 1978-1995. It was my "big" tractor on a 60 acre hobby farm. It was a great tractor, had 13.9 X 36 tires on it. It shifted well, never did anything to it except when I hooked up a 3 point log splitter to it, then it would plug up the hydraulic filter. I would have to pull it and clean it out. Put it back in and back in business. Sold it at my auction for $1000 more than I paid for it in '78. |
| cjn
11-15-2012 14:06:15
209.33.56.212
| There are many things I don't like about mine, but it keeps on plugging along and hasn't died yet. Who thought it was a good idea to have you 'glow-plug' a tractor when its 80 degrees out or when it's already warmed up? It takes 2-3 tries to start it in the summer, and 5-6 tries in the winter plus waiting 30 minutes before it becomes useful. Like was said in a previous reply. They tried to stuff too much into a little tractor. It would have been an awesome tractor if they could have pulled it off. A little bit ahead of its time. Just my 2 cents. |
| LJD
11-15-2012 13:32:51
75.213.38.179
| I like the 10 series crawlers. The ag tractors not so much. Brakes were never very good. Tractors got little to no aftermarket parts support. That being said - the 1010 and 2010 series had many "firsts" for Deere Co. First full size wet-sleeve engine. First diesel to use the Stanadyne-Roosamaster rotary injection pump. First Deere engine to use positive-type valve seals. First Deere crawler (1010) to have a hydraulic power-shift reverser. First crawler (2010) to have a hydraulic power shift Hi-Lo-Reverse transmission. Also - maybe the only indirect injected diesels Deere ever built? |
| buickanddeere
11-15-2012 12:51:01
184.151.61.92
| A gasser 1010 can be made to function decent enough. Either diesel or the 2010 chassis is trouble. |
| wisbaker
11-15-2012 12:30:34
207.118.181.192
| They weren't one of Deere's better ideas. As you mentioned they used the unique engine and realized it was a mistake and moved away from it pretty darn quick. It also seems they crammed a lot of stuff into a small framed tractor so getting to anything to work on is a PITA. In my opinion they were not as stout as the other new generation tractors, they don't seem to have the longevity their other tractors enjoyed, to put it another way if worked under the same percentage load of the tractor's rated capacity they just don't seem to run as long as a 4010 or even the 2 cylinders. |
| mkjd420
11-15-2012 12:57:47
99.103.129.178
Re: 2010 in reply to wisbaker, 11-15-2012 12:30:34
| finding a 2010 utillity with a good tranny is a task we ended up with a bad one with 3000 hours 1963 seen a guy scrap a nice one with 2200 hours and loader ours will not go into high gears with all new linkages , his was the same way , the tractor aint worth $4000 or $5000 to fix if your going to take a bath on restoring or fixing a tractor might as well bath in one you'll get your money back with one day |
| mkjd430
11-15-2012 13:01:19
99.103.129.178
Re: 2010 in reply to mkjd420, 11-15-2012 12:57:47
| owrs is going to end up as a pto power plant for a folly bell saw one day, it will cut small crap i think |
