630 coming out of gear
Anonymous-0
I am stumped bil has a 630 and you can be driving it in 4th or reverse and it will come out of gear but the shift lever never moves. I have had it apart and things look ok. Has new bearings, good countershaft and everything was set up to specs when we put it back together. I think it has to be in the (hi lo ) section where it is happening. any ideas would be appreciated. I did this when he bought it thats why we took it apart.
Do you feel the "Detents" positioning, when it goes in gear..??
They are spring-Loaded and should keep the gears in position..
The springs could break, or the Detents themselves may be worn and not indexing correctly..
Ron..
