50 governor
When at higher engine speeds the engine revs up to rpms higher than specs when it comes under load. As soon as I throttle back it returns to normal. This tractor is relatively a low hour unit. Has anyone had this experience? Thank you for any information!!
deereford
Could be a lot of things. Ajust the throttle linkage according to your service manuel. Make sure the linkage isn't binding. A weight could have come off inside the governor.
