TractorLinks.com
Show Parts for Model:
Re: JD 50 Compression Test
F-I-T
11-14-2012 09:25:47
When you get one that low, unless there is a chunk of deposit in the intake area restricting air flow into the cylinder, you should squirt a couple pumps of oil in, spin it few times, and measureit again. If it comes up, it's likely the oil has sealed worn rings. If it stays low, suspect a leaking valve. Then it's time for a leak down test, and use a length of garden hose to listen through hose to determine where the air is leaking out.
