Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: M steering shaft
11-13-2012 23:10:40
Sure it will but you'll have to make a new heavy washer to match the new id and the old od. Then there's the matter of finding a new cap nut in that size. Would be simpler to wrap the taper with a copper sheet to protect it, weld it up, turn it down and put the right threads back on. Never saw a good machinist yet that didn't enjoy a little challenge.
Do you know how to remove the sliding shaft? Unlock it and pull it out till you see the pin in the tube behind the dash. Drive it out and the short shaft will come out. If the notches are worn repair them while you're at it. I would put a new ball in there while it's apart.
11-14-2012 04:49:29
 Re: M steering shaft in reply to M-MAN, 11-13-2012 23:10:40
Sounds more complicated than I have time for. I may just replace it if I come across one. Gonna have to wait till spring for this probably. Getting very slow at work and will be laid off soon for awhile.
The cap nut is already has a regular one on it.
The nut is holding good so the steering wheel isn't going to come loose or anything. But I do want it fixed right later.
11-14-2012 07:53:05
 Re: M steering shaft in reply to JohnDeereM50, 11-14-2012 04:49:29
There was a NOS steering shaft on ebay a few weeks ago. I think it got to around $100, but I'm not sure if it met the reserve and sold or not. You could also try Rusty Acres Ranch or Dave Cook to see if they have a used one.
11-14-2012 16:13:58
 Re: M steering shaft in reply to Hotflashjr, 11-14-2012 07:53:05
I check ebay often but I missed that some how. I have gotten almost everything for it on ebay. Came across some great deals.
