John Deere 1020 Resistance Wire
My Resistance wire (John Deere 1020 Gas) is very brittle and keeps breaking. I called John Deere today to order a new one but they don"t sell just that wire. Need to buy the entire wiring harness. My question is: How can I replace this wire without buying the entire harness or should I just replace the coil with one that has a built in resistor?
Thanks in Advance
You could run a new wire and add an external ballast resistor or run a new wire and change the coil to one that doesn't require an external ballast resistor. Swapping the coil is neater and safer.
You can buy resistance wire in rolls. I'm don't think it's worth the bother though. I have 50 feet of it here.
1020 has a Delco starter that already has a built-in resistor bypass marked "R.". Just buy a stand-alone resistor and wire it in.
The OEM coil on the 1020 has 2.6 ohms on the primary. Just wire in a 1.6 ohm resistor and you'll be fine. # ICR11 at NAPA. Or buy a new coil that does not require any external resistor like a NAPA IC-14 (3.25 ohms on the primary) for the high-price Echlin coil (made in Mexico), or the NAPA MPE IC-14SB for the same in the much lower priced Chinese version. My tractor works just as well with Chinese volts as it does with Mexican volts.
