Yesterday's Tractor Co. Fast, Friendly Parts Service
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: 4020 lp running ruff
[Return to Forum]
midnightrider88
11-13-2012 19:38:38
216.249.220.124
I seem to have a problem with my lp 4020. I just replaced the seal in the strainer, along with replacing the spark plugs, air filter oil, wires, roter and distributor cap. Unfortunately I did all these items at the same time. It now seems to run fine at the start, but after it warms up, it doesn't run very good. It wants to die when any load is first applied, and just doesn't have any power. Again, when first started, it seems to go fine and have plenty of power, and after warmed up, no power, and wants to die when load is first applied. Could it be that it is not getting enough fuel, or did I screw up the timing? One other thing, if I open the throttler wide open, it sounds really upset, and sparks seem to come out of the muffler.
[Reply]   [No Email]
Tx Jim
11-16-2012 03:40:45
67.142.163.24
 Re: 4020 lp running ruff in reply to larryanderson, 11-13-2012 19:38:38
That appears to be electronic ignition instead of points but the distributor would still require correct timing.
[Reply]  [No Email]
midnightrider88
11-15-2012 19:12:01
216.249.220.124
 Re: 4020 lp running ruff in reply to midnightrider88, 11-13-2012 19:38:38
I think it has something to do with this lever that sets just under the distributor cap. Does anyone know what it is? I talked to our local john deere deal, and they had no idea (sometimes they surprise me). If I push it all the way to the right, it runs like crap. All the way left, and it seems to run like normal. It doesn't seem like there is any points involved with this.
[Reply]  [No Email]
Tx Jim
11-15-2012 03:54:35
67.142.163.22
 Re: 4020 lp running ruff in reply to Kent Petersen, 11-13-2012 19:38:38
midnightrider88 said: (quoted from post at 17:57:50 11/14/12) Is there a wy that I can check the points? I did have to pry the rotor off with a srewdriver, So don"t know if I could have messed somthing up there.
Set points with a feeler gauge but I can't remember correct setting. Some times it helps to just pass a $1 bill through the point contacts.
This post was edited by Tx Jim at 03:55:57 11/15/12.
[Reply]  [No Email]
midnightrider88
11-14-2012 13:57:50
164.154.249.82
I think I had sent the plugs to .015. Is there a wy that I can check the points? I did have to pry the rotor off with a srewdriver, So don"t know if I could have messed somthing up there. That thing was corroded on.
[Reply]  [No Email]
donmyeil
11-14-2012 13:07:51
74.32.241.119
Spark plug gap is different on lp than gas.
[Reply]  [No Email]
430WLPG
11-14-2012 10:40:39
166.181.3.199
Sounds to me like the points are too close
[Reply]  [No Email]
Tx Jim
11-14-2012 04:13:16
67.142.163.27
 Re: 4020 lp running ruff in reply to LJD, 11-13-2012 19:38:38
Did you replace points & condenser? Is distributor correctly timed?
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
