TractorLinks.com
Show Parts for Model:
natural gas
mkjd430
11-13-2012 09:23:27
whats it take to make an old 2cly john deere run on natual gas will a lp gas conversion run on natural gas any tec info on this subject would be grate
bob15
11-14-2012 15:37:55
 Re: natural gas in reply to gtx1967jewison, 11-13-2012 09:23:27
And your point is????
David G
11-14-2012 12:28:48
 Re: natural gas in reply to mkjd430, 11-13-2012 09:23:27
You will need to compress and liquify the gas to make it feasible.
buickanddeere
11-13-2012 12:07:22
A 4500psi compressor and a 4500psi tank the size of a 60 gallon water heater tank.
Tim S
11-13-2012 12:34:46
 Re: natural gas in reply to buickanddeere, 11-13-2012 12:07:22
Yes, that is the down side off natural gas...
Mike M
11-14-2012 06:53:07
 Re: natural gas in reply to Tim S, 11-13-2012 12:34:46
My first thoughts were it will be hard to not get tangled up in that long hose to feed it.
mkj430
11-13-2012 09:54:44
we got a gas well on the land and i think we can tap on the main distribution line for fulling over 200 wells on that line we get 125,000 cubic feet each on 2 houses hook up, its 250.0000 ft free on both places a year free, the rest is well head price, like to use it it cost us half a million to get this small well
Kurt_JDB
11-13-2012 14:38:31
 Re: natural gas in reply to mkj430, 11-13-2012 09:54:44
Why not get a natural gas fired electric generator and run your house/barn/shop and electric car?
Kurt
buickanddeere
11-13-2012 16:31:26
 Re: natural gas in reply to Kurt_JDB, 11-13-2012 14:38:31
Any old diesel runs just fine on natural gas. Just leave the injection pump at slow idle delivery rate. Add NG to the intake airflow with an ordinary NG or LP mixer. Have a governor control rpm by varying only the NG flow.
ss55
11-13-2012 15:31:27
Also check if your elecric company will buy excess electicity from you, and what they pay per Kilowatt-Hour.
mkjd430
11-13-2012 16:44:25
 Re: natural gas in reply to ss55, 11-13-2012 15:31:27
its my fathers gas he gets 125,000 cubic feet free for his home and my uncle gets 125,000 cubic feet we got two taps after that is well head price like $2.80 1000ft we are new to natural gas , i seen my dad friend run a 351 ford power sawmill using a gas line down the 2 barrle carb running it on both gas and natural gas , it cut reg gas use in in half, was wonder if 4 tanks mounted on a 60 jd on the air intake side would cut cost or a 3020 gas set up like that
buickandeere
11-13-2012 18:21:49
 Re: natural gas in reply to mkjd430, 11-13-2012 16:44:25
Crude half @ssee cob jobs like that cause fires, explosions, injuries and death. Who here can"t figure out the savings in fuel costs will easily pay for a proper mixer . Then safely and with the correct mixture run either gasoline or NG.
mkj430
11-13-2012 16:58:31
two tanks would fit on the side frame of a jd 60 2 short ones on the front make a steel safty cover pipe it in the front side of the carb dual fule , we are looking into gas lights gen and heat , you cant back feed a gen only solar or small wind turbine here, unless i run a small wind turbine off a small gas motor
Ron Wagner
11-13-2012 18:02:07
 Re: natural gas in reply to mkj430, 11-13-2012 16:58:31
I am trying to promote the use of natural gas farm equipment. Any stories, or other information would be helpful.
Natural gas is the future of energy. It is replacing dirty old coal plants, and dangerous expensive nuclear plants. It will fuel cars, vans, buses, locomotives, aircraft, ships, tractors, air conditioners, engines of all kinds. It costs far less. It will help keep us out of more useless wars, where we shed our blood and money. It lowers CO2 emissions. Over 2,700 natural gas story links on my blog. An annotated bibliography of live links, updated daily. The big picture of natural gas.
buickanddeere
11-14-2012 07:27:49
 Re: natural gas in reply to Ron Wagner, 11-13-2012 18:02:07
2,700+ plus links is a symptom to some sort or obsessive compulsive disorder.
buickandeere
11-14-2012 04:34:09
We see you single minded , blinkered and blinded advocates or zealots for any and every cause. Getting to the practical side and obeying the laws of physics. Modern coal plants run cheaper than gas and are clean. Why portray a coal plant from the 1940's? Not every building or machine is connected to a NG pipeline. Ever calculate the energy required to compress 4500 psi NG. Then the size, weight and short range limit applications to buses, trains and ships. Don't waste out time either telling us that cryogenic storage is practical for vehicles, airplanes, farm equipment etc. Given your years of experience working inside a variety of nuclear plants. You are certainly qualified to comment on the industry. Electricity from nuclear supplies power to locations and industry that NG can not provide a practical supply. Conversion of NG to alcohol using a catalist and nuclear steam will provide an economical source of liquid energy for mobile machinery and vehicles.. NG has it's place and most of the applications are already utililized. The current glut of cheap NG isn't forever either 5-10 years and the price will climb. There is centuries of coal and nuclear energy waiting to be harnessed.
mkjd430
11-14-2012 05:02:06
 Re: natural gas in reply to buickandeere, 11-14-2012 04:34:09
my dads a 3rd gen umwa deap mine coal miner my brother is to a 4th gen miner. My oldest brother is head mechanic in the operating engineers pipe line on 400 pieces of equipment ON the big gas well line my oldest brother is making $4200+ $1500 a week on the mechanics truck company truck to drive home every day pay for all his fule and gas and tourches GAS GAS FOR THE welders trucks gas + $65 A DAY FOR HIS RINO , A coal miner IN two weeks of 12 hours SHIFS will not bust $3200 in the coal mine
mkj430
11-14-2012 07:00:41
 Re: natural gas in reply to mkjd430, 11-14-2012 05:02:06
the company my oldest brother worked for he done saved them $140,000, they had a dozer blow up with a 140,000 engine core they had no core here they found a good core covered in trash in a dumpster on down the pipe line when he first got back
buickanddeere
11-14-2012 07:26:11
 Re: natural gas in reply to mkj430, 11-14-2012 07:00:41
Could you please explain that some more please?
Walt In Jaxn Tn.
11-15-2012 18:50:07
 Re: natural gas in reply to buickanddeere, 11-14-2012 07:26:11
"What" Who said anything about sniffing glue???????
