| John Deere Tractors Discussion Forum |
Topic: 63 JD 3010 - rear axle slipped out?
[Return to Forum]
| Author |
[Modern View]
| Tom bonehead
11-12-2012 10:57:43
75.145.255.169
With both rear wheels in the air, left side wheel engages and rotates through all gears - right side is free spinning (always). A quick measurement from sidewall to frame shows the right side is 1.25" further away from frame than left side. The right wheel axle seal also shows considerable (fresh) leak of fluid. This all leads me to believe, perhaps a snap-ring let go and the axle slid out of differential, disengaging the planetary gears? Comments? Thoughts? Any idea how i can tell if those rear tires are filled with anything? |
[Reply] [No Email] | |
| 2520-4010
11-12-2012 13:23:50
184.189.156.2
Re: 63 JD 3010 - rear axle slipped out? in reply to Tom bonehead, 11-12-2012 10:57:43
| Turn wheel so that the valvestem is low as it will go.......depress valvestem and check for liquid. ?? |
| 830 man
11-12-2012 13:22:51
174.228.66.216
| Rotate the valve stem to the bottom and push it in. If there is anything in there you will know it. |
| Tom Bonehead
11-12-2012 11:10:39
75.145.255.169
| When i put a wrench on the two retainer ring-wheel bolts, they were loose. Finger-tight |
| Tim S
11-12-2012 14:58:01
75.49.2.215
Re: 63 JD 3010 - rear axle slipped out? in reply to Tom Bonehead, 11-12-2012 11:10:39
| If your talking about the two pusher bolts they should be loose, you can pull and service the final drive with the wheel on. Use a floor crane and jack up the wheel till it will let the floor crane legs under then set it down on the crane legs as a dolly,drop a chain down from the mast ans hook to the axle housing.. |
| Tom Bonehead
11-13-2012 12:56:31
75.145.255.169
Re: 63 JD 3010 - rear axle slipped out? in reply to Tim S, 11-12-2012 14:58:01
| great post! Thanks everyone! wish me luck |
| Tim S
11-12-2012 11:01:52
75.49.2.215
| No snap ring,,the keeper and axle bolt backed away, probably because a bearing is bad, or the outer spacer got hammered up and let the bearing slack. The final drive will need to be pulled. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
