49 A waterpump
bigboreG
Was going to put a new core in the radiator of my 49 A, but the top tank has some cracks in it. So thats junk. I can get a complete radiator with water pump already on it and the core is like new from a friend of mine. Question is, other than the lower water pipe and longer belt,is there any other modifications that need to be made before i can install it?
No the A and G did not have thermostats. You should be good to go with some hose clamps and propper sized ruber radiator hose.
Hey bigboreG,
I installed a water pump on a mid 52 "A" and it was a little more work than I estimated. If you have the correct radiator lower tank that's a start. You will also have to use his fan shaft support because I think I had to modify mine to make it work. The biggest problem as I remember was the frame cross member is in the wrong place and you have to cut it out and move it back. Good Luck!
John
When you find the lower water pipe it will be blocked off half way to slow down the flow for proper cooling.
Also the fellows are correct as you will have to move the cross member back.
Rich
