| John Deere Tractors Discussion Forum |
Topic: Re: 4240 hydralic issue?
[Show Entire Topic] [Return to Forum]
| Author |
[Modern View]
| Tim S
11-11-2012 09:22:54
75.49.2.215
You can pick up a good 5,000psi gauge for about $35 screw a fitting on it and you have one..dealer service call plus an hour or so $$$$,,if you were closer you could borrow mine I have 4 or 5 of them ,,loan out to the neighbors a lot... |
| travz500
11-11-2012 09:26:04
76.7.23.114
Re: 4240 hydralic issue? in reply to Tim S, 11-11-2012 09:22:54
| well ok i may just do that then is there a certain kind of gauge? like something tractor supply or orchelins would have? then just hook it up to the remotes in back? thanks guys will do this week and try it out was afraid i may have a hydralic pump going out or something |
| DEEREMEYER1
11-11-2012 11:32:07
71.50.25.139
Re: 4240 hydralic issue? in reply to travz500, 11-11-2012 09:26:04
| Just a regular 2 1/4 inch or so pressure gauge will work fine. Spend a few extra bucks and get a good liquid-filled one and use bushings to thread it into a standard SCV hose tip. Of course the preferred way to check standby pressure is at the priority valve on the RH side of the tractor with a jumper hose and DR quick-connect. The pressure adjustment is at the hydraulic pump itself, so if you're plugged in at the side, you can watch the gauge while you adjust the stroke-control valve instead of needing a helper to watch the gauge at the rear. If you do plug into an SCV, while you're at it, you can check to see if any of your SCVs are leaking up or down. Plug the gauge in like normal with the lever in neutral. If there is pressure at the gauge, the pressure side of the valve is leaking. Stroke the lever to put pressure to the gauge and then return the lever to neutral and if the pressure drops off rapidly, you have a return leak. You'll have to repeat the procedure for both couplers in each SCV since there are two pressure valves and two return valves per SCV. |
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
