Yesterday's Tractor Co. Affordable Parts, Just in Time
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: 4240 hydralic issue?
[Return to Forum]
travz500
11-11-2012 05:30:21
76.7.23.114
i got a 81 4240 with 7200 hours and the hydralics are starting to whine some when gets warm and also the steering gets hard to turn when you have a bale on the front loader it wont turn like it used to have changed the filter and checked the sump screen and it was clean its a quad range the oil light never comes on. could this be the hydralic pump going bad? trying to determine whether to call the dealership to come up and look at it or take it to them
[Reply]   [No Email]
Tx Jim
11-13-2012 03:32:02
67.142.163.27
 Re: 4240 hydralic issue? in reply to Mike Aylward, 11-11-2012 05:30:21
Yes you are correct LH side bottom,front of pump
[Reply]  [No Email]
Tx Jim
11-12-2012 04:20:53
67.142.163.20
 Re: 4240 hydralic issue? in reply to Bob Foos, 11-11-2012 05:30:21
Screw is on frt hyd pump on LH side in frt of radiator. Loosen jam nut (#36) and screw in (CCW)(#37). Wear on hyd components causes these adjustments to be needed. Hyd lever needs to moved in the correct direction depending on which plug-in in the breakaway coupler is utilized. Move lever as if operating a one-way cyl.
This post was edited by Tx Jim at 04:24:36 11/12/12 2 times.
[Reply]  [No Email]
travz500
11-12-2012 19:46:45
76.7.23.114
 Re: 4240 hydralic issue? in reply to Tx Jim, 11-12-2012 04:20:53
so if i am looking at this correctly its on the left
side and on the bottom am I correct? thanks for the
information SIR!!
[Reply]  [No Email]
travz500
11-11-2012 18:55:13
76.7.23.114
 Re: 4240 hydralic issue? in reply to travz500, 11-11-2012 05:30:21
so where is the screw i need to turn if its low? do I put the lever all the way forward and lock it up there to check pressure? and one last question why does this happen what makes it low? age and wear? abuse? people I got it from seem to be very meticulous about maintenace and have very nice equipment
[Reply]  [No Email]
Tx Jim
11-11-2012 09:29:07
67.142.163.24
 Re: 4240 hydralic issue? in reply to 1 Dollar, 11-11-2012 05:30:21
Here's a gauge for $10.99
http://www.northerntool.com/shop/tools/product_48190_48190?cm_mmc=Aggregates-_-Shopzilla-_-Gauges>Filled%20Gauges-_-53617
[Reply]  [No Email]
Tx Jim
11-11-2012 09:20:53
67.142.163.24
 Re: 4240 hydralic issue? in reply to CharlesTX, 11-11-2012 05:30:21
It would be a lot cheaper to buy a gauge than have a dealer tech test the psi.
[Reply]  [No Email]
Tim S
11-11-2012 05:42:12
75.49.2.215
Stick a gauge into a remote outlet and see what the standby pressure is, you may need to turn the stroke valve screw in a bit to increase the pressure up to the 2250 mark
[Reply]  [No Email]
travz500
11-11-2012 08:18:54
76.7.23.114
 Re: 4240 hydralic issue? in reply to Tim S, 11-11-2012 05:42:12
thanks Tim but I dont have a gauge sounds like I may just need to call the dealership
[Reply]  [No Email]
Tim S
11-11-2012 09:22:54
75.49.2.215
 Re: 4240 hydralic issue? in reply to travz500, 11-11-2012 08:18:54
You can pick up a good 5,000psi gauge for about $35 screw a fitting on it and you have one..dealer service call plus an hour or so $$$$,,if you were closer you could borrow mine I have 4 or 5 of them ,,loan out to the neighbors a lot...
[Reply]  [No Email]
travz500
11-11-2012 09:26:04
76.7.23.114
 Re: 4240 hydralic issue? in reply to Tim S, 11-11-2012 09:22:54
well ok i may just do that then is there a certain kind of gauge? like something tractor supply or orchelins would have? then just hook it up to the remotes in back?
thanks guys will do this week and try it out was afraid i may have a hydralic pump going out or something
[Reply]  [No Email]
DEEREMEYER1
11-11-2012 11:32:07
71.50.25.139
 Re: 4240 hydralic issue? in reply to travz500, 11-11-2012 09:26:04
Just a regular 2 1/4 inch or so pressure gauge will work fine. Spend a few extra bucks and get a good liquid-filled one and use bushings to thread it into a standard SCV hose tip. Of course the preferred way to check standby pressure is at the priority valve on the RH side of the tractor with a jumper hose and DR quick-connect. The pressure adjustment is at the hydraulic pump itself, so if you're plugged in at the side, you can watch the gauge while you adjust the stroke-control valve instead of needing a helper to watch the gauge at the rear. If you do plug into an SCV, while you're at it, you can check to see if any of your SCVs are leaking up or down. Plug the gauge in like normal with the lever in neutral. If there is pressure at the gauge, the pressure side of the valve is leaking. Stroke the lever to put pressure to the gauge and then return the lever to neutral and if the pressure drops off rapidly, you have a return leak. You'll have to repeat the procedure for both couplers in each SCV since there are two pressure valves and two return valves per SCV.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
