John Deere 730D leaks diesel into oil
tuffy smith
New User
I have a John Deere 730D that leaks diesel into oil. I replaced the seals and had the drive gear micked and it is within tolerance. any ideas I have checked for parts but unable to locate any.
Any suggeations???
(quoted from post at 16:05:48 11/09/12) I have a John Deere 730D that leaks diesel into oil. I replaced the seals and had the drive gear micked and it is within tolerance. any ideas I have checked for parts but unable to locate any.
Any suggeations???
It's not uncommon for a re-sealed fuel transfer pump to still leak. If you dismount the pump let it hang free still connected, you might see if it is still leaking. If it is dry. look into the injector pit for a cracked line, etc..
"I have checked for parts but unable to locate any"...
What parts?
