Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: John deere 40 spark plug problems
Cockbird_Hunter
11-06-2012 09:50:37
The most common failure I have seen is dirty contacts internally/externally on the dash ignition switch. Often, I have measured a strong 6-7V at the negative coil lead & still have had problems.
The best quick test, assuming it is original 6V positive ground system, is to run a test jumper lead from large negative battery lug on the starter directly to the negative coil terminal, thus bypassing the ignition switch.
I have disassembled many Dubuque ignition switches & cleaned the contacts as a cure to all electrical system issues assuming the harness is not at fault.
