TractorLinks.com
Show Parts for Model:
Re: JD M oil filter housing sealing plate.
CaseRider
11-06-2012 07:30:17
Good info here.
M-Man, do you use the Fram filter, dealer filter, or something else?
Also, if you really want a plate (M88T) you can get a mostly equivalent part from the dealer. When I was rebuilding the tractor, the JD parts guy was really helpful and pulled the factory drawing and found a couple of equivalent parts used on other JD tractors from this era. It's been a while since I rebuilt the tractor, but I'm sure I saved the plastic bag with the part number on it. Next time I'm out that way I'll look and see what the number was.
M-MAN
11-06-2012 08:07:56
 Re: JD M oil filter housing sealing plate. in reply to CaseRider, 11-06-2012 07:30:17
I use either Deere or NAPA depending on whether I remembered to pick one up at the dealer. WIX makes both so it doesn't matter where it comes from. Got my last set of plates from Sharps.
