| John Deere Tractors Discussion Forum |
Topic: My Poppin' Johnny Won't Pop
[Return to Forum]
| Author |
[Modern View]
| Travis W
11-05-2012 18:48:08
209.169.74.172
1949 model A - starter recently rebuilt, battery is charged, and it turns over great. Rebuilt carb; gas is getting to it. BUT, NO FIRE. Has a WICO X magneto on it; I replaced the rotor. A friend thinks it could be out of time - but I thought it would start and run badly. I thought it might be the condensor. Any help appreciated. Not a drop of oil in the oil bath; but I don't know that this matters. Ken |
| F-I-T
11-16-2012 12:07:57
184.6.247.3
Re: My Poppin' Johnny Won't Pop in reply to Little Red, 11-05-2012 18:48:08
| Quoting Removed, click Modern View to see
Just to be sure, open the bowl drain on the carb and make sure it delivers a pencil sized stream for a full minute. Catch the gas and pour it back in the tank.
Compression good? No sticky valves? You say good spark. Timing right?
I sort of forgot where you are on this machine. |
| Dandy Dave
11-16-2012 06:08:27
74.209.22.43
Re: My Poppin' Johnny Won't Pop in reply to Travis W, 11-05-2012 18:48:08
| You may need to see if the carb leaks without the tractor running. Like F_I_T said, Hold it away from the manifold and turn the fuel on to see if you have a leak. Could be dirt under the needle and seat letting the fuel get by. Also, could be that the Carb vent is pluged. These are often overlooked. Dandy Dave! |
| Travis W
11-16-2012 05:36:42
32.157.109.144
| | Ok, now I am really stumped. Got the carb off per the advice of you fine folks. Made some adjustments, and got it back on. It took a while, but it started- and ran GREAT! I let it idle for about 10 minutes and shut it off. I called a friend over to hear it run- it wouldn"t start. It took 30 minutes to finally get it cranked again, and then it died and would not restart. At first, when it first started, the smoke was black. It did not contune smoling. Subsequent attempts showed white smoke- which I thought indicated it was too lean. At any rate I don"t know why it is so hard to get started. I welcome any advice. I have checked, replaced, and checked the plugs again. The magneto is sparking - you can see it at night. |
| F-I-T
11-12-2012 05:08:38
184.6.247.3
Re: My Poppin' Johnny Won't Pop in reply to Tx Jim, 11-05-2012 18:48:08
| To determine if I have a spark or not, I like to hook a timing light to a wire and see if she blinks.
On the fuel issue, loosen the carb at the manifols, and drop a couple of 7 penny nails or similar rods down from thge top on either side of the bolts to hold the carb away from the manifild. Now watch to see if fuel is leaking at this point, and if so, correct your float needle and or seat. |
| Travis W
11-12-2012 04:18:56
209.169.110.253
| | Kurt - thanks for the response. I replaced the condensor and the points, as well as the rotor and the magneto cap (large black plastic cover with WICO on it - forgive me if the terminology is not all 100% correct). I also replaced the plugs and wires. What I"m seeing is that the clutch side cylinder has gasoline POURING out of the petcock. My thinking is that I have a carb problem still. I"m open to suggestions, as well as links or materials you might have that could help out here. |
| JohnDeereJimOhio
11-06-2012 05:20:57
204.9.147.16
| Start with the magneto make sure coil and condensor ar working. Di you have the Mag of then it could very well be out of time and not run... |
| Greenday
11-06-2012 04:50:30
204.185.166.101
| Unless the mag was recently removed how would it get out of time? |
| Old Popper
11-06-2012 15:55:50
216.51.202.134
Re: My Poppin' Johnny Won't Pop in reply to Greenday, 11-06-2012 04:50:30
| Make sure top wire goes to "flywheel side" plug |
| Kurt_JDB
11-06-2012 04:46:45
74.167.224.109
| | Travis, By "no fire" do you mean that the magneto is not producing a spark? I agree with the comment that this could be points. The contacts can become oxidized if they sit a while. You might try passing a dollar bill between the points while holding them closed. Could also be your coil is bad, or a loose connection, or the condenser, Or the cap, or rotor. or the impulse spring might be broken. Does the mag give a good snap as you turn it? If you don"t hear that snap, then the mag is not turning fast enough to generate a spark as you are trying to start it. Anyway, I would start with the points if it is not making a spark. Kurt |
| gtx1967jewison
11-05-2012 20:30:49
174.253.144.95
| rusty wheel
11-05-2012 18:59:26
75.180.23.218
| A bad condenser will cause your problem. It's easy to check the timing. Remove number one plug, hook the wire to it and ground it. Bring number one piston to tdc slowly just until the plug fires. See if the timing mark on the flywheel is lined up with the emboss mark on the casting. Should be about 3 oclock. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
