Deere 435 Live PTO Option
Crgmor
New User
Hi, does anyone know if the 435 (w Detroit Diesel Engine) had a standard option live PTO or was it a order extra item?
If it had to be ordered extra, what would the option look like? Similar to the standard PTO enguage lever or different?
Thanks
Craig
Live PTO was an option. All the LPTO specific parts are inside the torque tube/transmission case so nothing is visibly obvious from the outside. Most of the time you can feel the two stages of the clutch as you depress the clutch pedal; also most LPTO tractors have a stud/nut in the top hole at the forward torque tube vs. standard bolt.
