Yesterday's Tractor Co. New Parts for Old Tractors
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Re: Wico X Mag
[Show Entire Topic]  [Return to Forum]
John T
11-05-2012 14:47:53
216.249.82.117
A simple low voltage ohm meter test will tell you if its really BAD (like the LV Primary or HV Secondary is open) but it cant tell you if its really GOOD since many failures involve High Voltage Breakdown and/or occur only after its warmed up and under actual operating conditions. The LV Primary is less then 1 ohm while the HV Secondary is several thousand ohms and if either is open its obviously bad.
The most common cause of mag failure to spark is the points are burned or pitted or even gray oxide coated any of which kills the spark. You might clean n light file them and gap them n see if that cures the problem and replace if badly burned or pitted. Likweise a bad condensor can cause no spark.
Since points and condensor are relatively cheap compared to the coil if the coil passes both continuity tests and doesnt appear or smell burned Id suspect points and/or condensor first.
For the impulse cranking spark to happen the mags wind n trip spring assembly has to be working and it yields a good sharp SNAP each 180 of rotation otherwise no spark at cranking speed.
John T
[Reply]   [No Email]
Buddy Woodson
11-05-2012 15:14:08
76.122.192.3
Re: Wico X Mag in reply to John T, 11-05-2012 14:47:53
Thanks, exactly where do you touch the leads of the tester?
  [Reply]  [No Email]
John T
11-05-2012 15:34:16
216.249.82.117
Re: Wico X Mag in reply to Buddy Woodson, 11-05-2012 15:14:08
The LV Primary is between the little wire from the coil that connects to the points and case frame, points need to be OPEN...The HV Secondary is from the coils side output button/terminal (where caps springy touches) to case frame. If it has the side push springy kill switch that also is the wire from coil to points and with points closed you should show 0 ohms to case frame but with them open the less then 1 ohm which would be again the LV Primary of the coil. NOTE the condensor wire also attaches to the points where the coil wire does so that should be removed cuz if the condensor were a short that messes up the LV coil primary measurement.
John T
  [Reply]  [No Email]
Buddy Woodson
11-05-2012 15:31:45
76.122.192.3
Also, should the coil fit snug on the cross bar? Mine is loose.
  [Reply]  [No Email]
John T
11-05-2012 15:35:42
216.249.82.117
Re: Wico X Mag in reply to Buddy Woodson, 11-05-2012 15:31:45
It should be fairly snug, thats the purpose of the little paper wedges that fit between the coil center where the bar passes through.
  [Reply]  [No Email]
[Show Entire Topic]     [Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
