TractorLinks.com
Show Parts for Model:
Re: What direction does a 39 A fan travel??
Mark-Ia
11-05-2012 14:44:42
When standing on the flywheel-side of the tractor, the fan turns counter clockwise. When you install that fanshaft, you will need to put the proper amount of shim gaskets between the fanshaft and gov. housing. To give the gov. gear and fan gear the correct heal and toe clearance to eliminate excessive wear and a really noisy howl........
Farmallb
11-05-2012 16:09:08
 Re: What direction does a 39 A fan travel?? in reply to Mark-Ia, 11-05-2012 14:44:42
Is that shims between the casting on the shaft and the gov, OR between the holding stand and the cast part where the oil goes in, OR both
Mark-Ia
11-05-2012 16:38:42
 Re: What direction does a 39 A fan travel?? in reply to Farmallb, 11-05-2012 16:09:08
There are shims(gaskets) where the fan shaft bolts to the gov. housing. No shims used on the front stand. Download your Free parts manual at JDPARTS
Farmallb
11-05-2012 16:07:07
