brakes on john deere 60
terry howell
New User
iam tryong to get infomation on the removle of the bushings in the brake housing on a 1952 john deere 60, any help would be appraciated. thanks.
What would be your concern....strip down the unit....drive out the bushings....but most likely your shaft surface is going to be worn and this would be the greater concern and there's not much you can do to this...might resurface and get larger bushings....pretty simple fix but you have to get off tractor strip them down before you can do any good....
