4430 problems, metal shavings
Its a quad shift, the power steering doesn't turn like it should. The 2 pt hitch sometimes comes up about half way then stops, then after a few seconds it will continue going up real slow. The hydraulic outlets work prefect though. Drained the hydraulic oil and there are a lot of metal shavings in it. These metal shavings are really really fine, no big chunks or anything.
So were are the metal shavings coming from?
Thanks!
Your brakes will work fine,as they continue to eat themselves up, if that is your problem. I pull a lot of final drives just to check,,it"s worth the effort to know...
