Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
what is the year of this serial number
John Hendriks
11-02-2012 20:47:07
Does anyone know what year these tractor serial numbers are:
John Deere Serial # 258894 what is the value of each tractor?
John Deere Serial # 277460
Any assistance would be helpful.
John Saskatchewan Canada
A GURU
11-04-2012 18:39:24
 Re: what is the year of this serial number in reply to John Hendriks, 11-02-2012 20:47:07
AR-AO 258894 would have likely been built close to the very end of March 1940 (1940 model). AR-AO 277460 would have been built somewhere around the second week of April 1951 (1951 model). Just a rough estimate based on some known numbers, and some math. If you want the exact details on each you can contact Two-Cylinder Club to have each serial numbers researched.
Hope this helps.
John Hendriks
11-04-2012 20:48:48
 Re: what is the year of this serial number in reply to A GURU, 11-04-2012 18:39:24
Thanks for your help.
CLW
11-03-2012 22:49:59
 Re: what is the year of this serial number in reply to tomstractorsandtoys1, 11-02-2012 20:47:07
Then one is a 1940 AO or AR and the other is a 1951 AO or AR. The owner don't know what they are?
CLW
11-03-2012 17:32:56
 Re: what is the year of this serial number in reply to Ray, 11-02-2012 20:47:07
A 1950 serial number will be in the range from 253025 to 275241. The range of a 1951 is 275242 - 293029. Your tags should say B258894 and B277460.
CLW
11-03-2012 08:58:30
 Re: what is the year of this serial number in reply to Blksmok, 11-02-2012 20:47:07
Does it look anything like this?
Mark-Ia
11-03-2012 05:12:54
You can look up ser# in the "Research and Info" column here on the left side.
John Hendriks
11-03-2012 08:24:24
 Re: what is the year of this serial number in reply to Mark-Ia, 11-03-2012 05:12:54
Yes Thanks Those numbers are not listed,any other suggestions
Mark-Ia
11-03-2012 17:03:15
 Re: what is the year of this serial number in reply to John Hendriks, 11-03-2012 08:24:24
You will need to find the ser# range that your numbers fit into. It won't list your specific number, but somewhere between the numbers listed. Do you have a B or AR?
John Hendriks
11-03-2012 22:16:21
 Re: what is the year of this serial number in reply to Mark-Ia, 11-03-2012 17:03:15
It has an A in front of the numbers according to the owner.
FWB in SK
11-02-2012 22:15:14
IF they are John Deere B,s they are a 1950 and a 1951
CLW
11-02-2012 22:11:41
 Re: what is the year of this serial number in reply to Greg Knapp, 11-02-2012 20:47:07
John, I am going to guess they are model B tractors. B should be on the tag just ahead of the numbers you posted. If they are B's the 258894 would be a 1950 model. The 277460 is a 1951. Without a picture or more information we can't put a price on them. Do they run? Do they have good tires and sheet metal? Do they have a wide front end? How is the paint?
There is a chance they are AO or AR tractors also. Pictures would sure help.
If you can't post a picture email it to me and I will post it for you.
clwebbfamily@sbcglobal.net
