Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
4430 problems, metal shavings
johndeeregreen
11-02-2012 17:41:29
Its a quad shift, the power steering doesn't turn like it should. The 2 pt hitch sometimes comes up about half way then stops, then after a few seconds it will continue going up real slow. The hydraulic outlets work prefect though. Drained the hydraulic oil and there are a lot of metal shavings in it. These metal shavings are really really fine, no big chunks or anything.
So were are the metal shavings coming from?
Thanks!
johndeeregreen
11-04-2012 05:18:42
 Re: 4430 problems, metal shavings in reply to johndeeregreen, 11-02-2012 17:41:29
Thanks for all the info, when I get time I'll start tearing it apart.
johndeeregreen
11-03-2012 17:27:31
My brakes still work good, did yours?
onefarmer
11-03-2012 18:35:34
 Re: 4430 problems, metal shavings in reply to johndeeregreen, 11-03-2012 17:27:31
Yep brakes were just fine. Maybe a bit more grabby but stopped and held good.
Tim S
11-03-2012 17:59:12
Your brakes will work fine,as they continue to eat themselves up, if that is your problem. I pull a lot of final drives just to check,,it"s worth the effort to know...
onefarmer
11-02-2012 17:58:35
Been thru this on a 4430 and a 4320. I'll bet your brakes are worn out and the shavings are from the pads grinding on the disk. Don't drive it except to the shop, if it's close.
