Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
4620 fuel trouble
tater61
11-02-2012 08:55:16
I was plowing for 30 minutes, when the tractor slowly lost power and stopped.I waited 10 minutes and restarted it. This happened several times and will now only run for 10 minutes.
onefarmer
11-02-2012 18:21:25
 Re: 4620 fuel trouble in reply to tater61, 11-02-2012 08:55:16
I'd make sure you're getting fuel flow and pressure to the i-pump. Might be a plugged in-tank screen, plugged line, bad lift pump, or just your basic fuel filter.
DEEREMEYER1
11-02-2012 09:37:16
It's not automatically the fuel injection pump, although that is a distinct possibility. Other possibilities are debris in the fuel tank getting sucked over the tank outlet and a plugged fuel cap vent.
Dieseltech
11-02-2012 09:34:10
Governor flex ring is failed inside injection pump, plugging return fitting and possibly return line also. Confirm by loostening timing window cover when it starts to die. If engine picks up speed and runs OK with cover loose, pump needs serviced to correct.
Copyright © 1997-2015 Yesterday's Tractor Co.
