Help with installing Fan assembly on 39 A
Farmallb
Ive tried all I know, including cracking the pot metal inside the friction disc.
Im thinking of sending a print out of the assembly to my biker SIL. hes a good machanic, where Im lousy at it. IF anybody can send a printout to him, please let me know and ill send you his E mail. Thanks.
He may have ideas I havnt thought of, OR maybe we can tag team it together.
Do you need a parts breakdown or a book? Parts book can be had at WWW.jdparts.com . Others will chime in.
Question ? Did you start out with a rubber mounted fan hub and then are now switching over to the friction disk type ?
There was no rubber mounted on anything. There were no friction pads. This was a parts tractor, and I bought the parts as I saw them on the I & T manual that I didnt have. All Ive got is the 2 friction discs, spring pulley and fan, and keeper.
Well, I finally figured out a way that ought to work. I backed my H up to my post vice mounted on a stump. I was going to lay the shaft on the axle and put the pulley and end friction disc in the vice, and put my C clamp on top and bring it in. Went to look for the keepers, and there gone. Tractors been setting outside for 2 yrs. Under trees. All kinds of leaves and grass. I couldnt find one outa 3 parts with 2 magnets.
SO
Is that a special part, or can I get it somewhere. If so, Whats the sizes?
http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt
This is the link for the parts country website. scroll down to number 675. thats the manual for 1939 and up A"s
Untitled URL Link
Two C-clamps as to draw it up evenly with very litte pressure is all that is needed to assemble one. Something is just not correct. Likely mismatched parts.
