TractorLinks.com
Show Parts for Model:
Fuel question
jimwa
10-31-2012 20:48:21
Mr thinker recommended using number 1 diesel to clean out the diesel tractors that don"t get enough work. I went to purchase number 1 diesel and they took it from a kerosene tank. They said heating oil # 1, kerosene and diesel # 1 are all the same. Then they said I shouldn"t use straight #1 but mix it with #2.
What do you think?
DEEREMEYER1
11-02-2012 09:11:49
 Re: Fuel question in reply to jimwa, 10-31-2012 20:48:21
#1 is a ligher, thinner fuel with lower energy content and really isn't recommended for use except in very cold conditions. There are plenty of diesel fuel additives that will give you the results you're looking for simply by adding them to #2 fuel.
PopinJohn
11-01-2012 18:28:07
Depends on the climate, hot vs cold. I remember reading that "winterized" #2 Diesel is blended with #1 for use below freezing temperatures. #2 Diesel will gel in cold weather. I don't see anything wrong with Mr. Thinkers suggestion in the context he provided.
nlastovi
10-31-2012 21:45:11
According to BP:
http://www.fuelcertification.com/docs/fuel-composition/Distillate_Fuel_Classifications.pdf
Grade No. 1-D and kerosene are very similar in their
physical characteristics although different in their
specifications. Therefore, sometimes their names
are used interchangeably by customers. The
specification for 1-D fuels is based on the fuelís ability
to perform in a diesel engine as opposed to the
specification for 1-K fuels, which is based on heating
appliance applications. 1-D and 1-K have different
specifications, but because they are so similar, one
fuel is often made to meet both 1-D and 1-K
specifications. Check with your BP, Amoco or Arco
supplier to determine if 1-K can be substituted with 1-
D. The biggest difference between 1-K and 1-D is in
their end use, the application of road taxes, and
maximum sulfur content levels.
The grade 2-D (also called #2 or No. 2 diesel fuel) is
designed for use in heavy duty trucks, construction
equipment, farm equipment, diesel passenger cars,
etc. Most diesel engines are designed to burn 2-D
fuel. Itís a "heavier" fuel than 1-D (lower API gravity
than 1-D) and it has higher BTU/gallons (more
miles/gallon and more power). No. 2 diesel fuel from
Arco, BP, and Amoco is an economic 40-cetane
minimum, high BTU, ASTM No. 2 grade diesel fuel.
For further information on BP fuels, contact:
BP Quality & Technical Service
Phone: 1-800-841-5255
BP Naperville Complex
150 West Warrenville Road
Naperville, Illinois 60563-8460
Website: www.bp.com
4/01
leon
11-01-2012 07:46:40
 Re: Fuel question in reply to nlastovi, 10-31-2012 21:45:11
So, discuss some about your thought on using No. 2 Diesel with cold weather additives versus using straight No. 1 Diesel - I'm thinking of when the temp's drop well below freezing, say down to -20F.
wijim
11-01-2012 16:42:59
 Re: Fuel question in reply to leon, 11-01-2012 07:46:40
Around here we blend 30% NO 1 TO 70% NO 2 for winter. Jim
donjr
10-31-2012 21:07:46
#1 or kerosene is good for winter fuel, but it won't get the work out that #2 will. It will help clean the injectors, as will many of the additives on the market. But #2 is the preferred fuel.
