TractorLinks.com
Show Parts for Model:
3010 JD 1000 PTO delete
ToddOH
10-31-2012 18:25:10
I have my 3010 split apart right now replacing the shifting pin for the 540pto for the 3rd time. I am wondering if anyone can explain how to remove these small pins so I am not splitting this tractor every winter. I have read the other posts and can't figure it out right now. Any pictures or better explanations would be greatly appreciated.
Thanks
Tx Jim
11-02-2012 03:03:10
 Re: 3010 JD 1000 PTO delete in reply to Golfcartman, 10-31-2012 18:25:10
A Welch plug is an expansion plug.
ToddOH
11-01-2012 20:19:21
 Re: 3010 JD 1000 PTO delete in reply to ToddOH, 10-31-2012 18:25:10
Tx Jim, I took your idea today and ran with it. I got a couple 1/4in grade 8 bolts like you said. I removed all of the insides of the shaft. I also am having a machinist make a spacer to replace the 1000 rpm gear. I forgot to pick up lock nuts so I will pick them up tomorrow. My question now is what do you mean by a welch plug?
Glad to be gaining ground on this thing!! Thanks Guys!!
Tim S
11-01-2012 09:01:13
I"m in Mexico right now away from my home computer, so I don"t have my pics handy,,but what i do is remove the springs and plungers, and the 1000 gear, push the 540 collar into place then I fab a "T" shaped piece of metal out of 1/8" stock to fit into the slot in the shaft, letting the "neck" of the "T" up against the collar then a washer and snap ring up to hold it in place,,Years ago we thought cutting a new snap ring groove was a good idea,,"BUT" in hard use the shaft would break where we cut the new groove,,so it was a great idea that didn"t work out,,so then I came up with the "T" thing,,there are other ways to do it also, but the idea is to hold the collar in gear with out the darn pin...
Tx Jim
11-01-2012 03:45:44
 Re: 3010 JD 1000 PTO delete in reply to LonM, 10-31-2012 18:25:10
Todd
I removed one shift collar & pin(parts keys 27 & 29),1000 rpm drive gear(parts key #33) & all the shifter rod components inside pto shaft except the screw(parts key 40A/40B). I inserted in the slots the largest diameter bolt with locking nut on each side of 540 drive gear(parts key #32) along with correct number of shim washers to hold 540 drive gear in correct position with one shift collar(parts key #29) to power 540 gear. One also needs to remove stub shaft and install a welch plug to keep oil from leaking out of drive shaft and then reinstall stub shaft. I altered several tractors such as I stated back when I was a JD dealer service manager and never had a customer complaint.
Tim S stated he built something to hold 540 gear in correct place.
This post was edited by Tx Jim at 04:21:47 11/01/12.
