Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: 1944 B Transmission
Sam Vastano
10-31-2012 13:20:28
Probably a worn gear and or bearing. ON the sliding shaft. Could possibly be a weak spring on the detent shaft but highly unlikely
Hope this helps
Sam
Bob in Illinois
10-31-2012 13:39:24
 Re: 1944 B Transmission in reply to Sam Vastano, 10-31-2012 13:20:28
Thanks for the feedback. I haven't tried to get in there and was wondering how deep I will have to go to deal with it. After the first time I kept my eye on it and watched it work out of gear. Took about 200 hundred yards or so. Doesn't do it in any other gear. Can I access the gears from under the floor plate ?
Sam Vastano
10-31-2012 14:04:36
 Re: 1944 B Transmission in reply to Bob in Illinois, 10-31-2012 13:39:24
Yes if you take the topcover off you should be able to inspect the shaft, gears & do some wiggling to see if the bearing is tight. If it is the bearing/gear etc then you have to take the reduction gear cover off to get it fixed up.
Sam
