JD301 Reverser
dgr427
New User
My JD301 tractor is leaking trans/hydraulic oil from the two oil seals on
the reverser. The service manuals seems to indicate that I have to
completely disassemble the clutch housing etc to replace those two
oil seals, is that true or would I be able to get at them by removing
the front plate?
Thanks
Splitting at the clutch housing and removing the front plate will let you service the forward clutch pack and front seal, but not the reverse set...
