| Author |
[Modern View]
| franklin smith
10-29-2012 17:17:28
173.19.12.178
what should it cost to over haul power sterring column on a 2040 jd tractor? |
| Tx Jim
11-02-2012 03:59:43
67.142.163.27
Re: 2040 jd oil leak on stering column in reply to Ray Durham, 10-29-2012 17:17:28
| MSD
It soaked into my pee brain that what you posted was on the pages I'd been looking up but that I didn't scroll to the bottom of the page. If you plug in the part #L34451 that table you posted is worthless unless I overlooked something as I see no "Urathane" |
| MSD
11-02-2012 19:35:36
67.4.60.56
Re: 2040 jd oil leak on stering column in reply to Tx Jim, 11-02-2012 03:59:43
| TX Jim, I see what your saying. I noticed if it is a rubber o-ring, it won't even give the chart I showed. Might be if it is in the HB family, it shows what the code means as there are different properties for the different codes. Or it could just be a JD thing that shows up on some things and not on others. |
| MSD
11-02-2012 19:37:37
67.4.60.56
Re: 2040 jd oil leak on stering column in reply to MSD, 11-02-2012 19:35:36
| Tx Jim
11-01-2012 11:47:51
67.142.163.25
Re: 2040 jd oil leak on stering column in reply to rick165, 10-29-2012 17:17:28
| Quoting Removed, click Modern View to see
There is no way that I'd pay $600 for a JD dealership employee to put seals in that steering valve. That's way too much $$$$$ |
| Tx Jim
11-01-2012 09:31:23
67.142.163.27
Re: 2040 jd oil leak on stering column in reply to JDTECH, 10-29-2012 17:17:28
Where does one look on JD's website to find that information??? |
| MSD
11-01-2012 19:03:05
67.4.60.56
Re: 2040 jd oil leak on stering column in reply to Tx Jim, 11-01-2012 09:31:23
|   If you sign into their web site and put in the part number (in this case T25335) it will give the specifications in a box. Below that is a part diagram and in real fine print it gives a key to what the materials are. The printing is kinda fuzzy on their web site also. |
| Tx Jim
11-01-2012 03:20:52
67.142.163.20
Re: 2040 jd oil leak on stering column in reply to jddave, 10-29-2012 17:17:28
Does anyone know what material is H4B?
T25335
Specification
Weight 0.00 LBS 0.00 Kg
Inside Diameter 1.864 IN
Nominal Section 0.070 IN
Standard Number Code A
Standard Number Size 032
Durometer 90
Material H4B
L34451
Specification
Durometer 90
Material URETHN |
| MSD
11-01-2012 09:24:32
67.4.60.56
Re: 2040 jd oil leak on stering column in reply to Tx Jim, 11-01-2012 03:20:52
| JD website shows H4B as: Nitrile Elasmer. Doing a Google search I found this page. http://www.bkvthermal.com/elastomericnitrile.html |
| MSD
11-01-2012 09:29:59
67.4.60.56
Re: 2040 jd oil leak on stering column in reply to MSD, 11-01-2012 09:24:32
| Spelled wrong again. It should read Nitrile Elastomer. |
| Tx Jim
11-01-2012 03:07:34
67.142.163.20
Re: 2040 jd oil leak on stering column in reply to indiana george, 10-29-2012 17:17:28
You can order a TM from JD. I personally think the hardest part of resealing the steering valve is installing the 6 larger o-rings in the correct grooves. As previously stated only disassemble the shaft with the valves if absolutely necessary,
Technical Manual CD-ROM TM4300CD 2040 Utility Tractor |
| S.C.
10-31-2012 18:08:43
174.255.83.39
Re: 2040 jd oil leak on stering column in reply to franklin smith, 10-29-2012 17:17:28
| Looks like the one on my 2030. Took it apart and some of the shims were damaged. Went to Deere dealer to get parts. It takes some special tools to get the shaft apart and the parts guys talked me into leaving it there for one of the mechanics to look at and shim the valves. Went back to pick it up and when I got the bill I was in shock. The new shims were about $20, time was about one hour, and the total bill was almost $450. I'll never let Deere work on anything for me again. I should have made the tool I needed and done it myself. Best advice I can give is BUY THE DEERE SERVICE MANUAL and do it yourself. |
| franklin smith
10-31-2012 18:50:03
173.19.12.178
Re: 2040 jd oil leak on stering column in reply to S.C., 10-31-2012 18:08:43
| SC WHERE CAN I GET A GOOD SERVICE MANUAL. THE ONE I HAVE IS IT AND IT IS NOT THOROUGH ENOUGH. |
| franklin smith
10-31-2012 18:39:41
173.19.12.178
| That is what I am afraid of ,one dealer near me would not give me an estimate and wanted me to bring in my tractor to do the job.I have a friend with a ford tractor and he said a shop near him gave him a price of 1000 dollars to over haul the steering column.I am going to look for me a shade tree mechanic and see if he will help me do mine. |
| Tx Jim
10-30-2012 04:04:23
67.142.163.24
| [quote="MSD"](quoted from post at 20:39:24 10/29/12)
MSD
I think you mistyped a numeral.
The part number I saw was L34451 for parts key #4 not L33451
T25335 o-ring 1.45 (6) 2040 calls for L33451. It is the same dimensions but different material and about the same price
| MSD
10-31-2012 21:24:48
67.4.60.56
Re: 2040 jd oil leak on stering column in reply to Tx Jim, 10-30-2012 04:04:23
| My mind tells me one thing and my fingers do what they want sometimes when I type. Good catch. Wonder what the difference in material is? Strange they don't sub out also. |
| franklin smith
10-31-2012 16:46:26
173.19.12.178
| Well now after running the 2040 to load it at my farm and bringing it to my home garage i noticed the sterring colum is leaking at the bottom flange.Is this repair very complicated? I am going to have to pull whole column from tractor. I have a over haul manual but what are some things I should be careful about.How much would a jd shop charge to do this job. Franklin |
| Tx Jim
10-30-2012 03:56:34
67.142.163.24
Re: 2040 jd oil leak on stering column in reply to Bob Harvey, 10-29-2012 17:17:28
| franklin smith
Is your 2040 open or closed center hyds? Normally a parts kit is cheaper than individual part numbers. I noticed the kit has 10 part numbers instead of MSD's 6 part numbers. AT315816 KIT, OVERHAUL ADD 72.86 USD
This post was edited by Tx Jim at 04:06:53 10/30/12. |
| MSD
10-31-2012 21:31:06
67.4.60.56
Re: 2040 jd oil leak on stering column in reply to Tx Jim, 10-30-2012 03:56:34
| I didn't change out the o-ring backers and made my own gaskets. Still cheaper than the kit. JD wanted over $10 for the top seal where I got it for less than $4. |
| franklin smith
10-30-2012 10:12:10
173.19.12.178
| My hydraulic system is open center from what I am reading on this site. My tractor is a 1976 model. |
| MSD
10-29-2012 17:39:24
67.4.60.56
| | I just got done resealing a 2020 and it is about the same. Here is my parts list and costs. I made my own gasket which is $4 something from JD. My parts run a little higher because I get them through a construction dealer but he is only 3/4 mile away so it is worth the extra. F3450R o-ring 4.86 (1) B3690R o-ring 3.94 (1) T25335 o-ring 1.45 (6) 2040 calls for L33451. It is the same dimensions but different material and about the same price U12331 o-ring 3.77 (2) R26448 o-ring 1.69 (1) NTL471267 seal 3.93 (1) got this from local bearing shop |
| franklin smith
10-29-2012 23:35:20
173.19.12.178
Re: 2040 jd oil leak on stering column in reply to MSD, 10-29-2012 17:39:24
| Thanks MSD for the information.I may try and do it my self. I also need to put another seal in my pto shaft. I wonder if pto seal can be bought from auto supply? The one i put i from jd seemed to be a little big and i damaged it putting it in and it is leaking.It was all covered in rubber material and hard to drive in.I recon i needed a special tool to install it? |
| MSD
10-31-2012 21:36:27
67.4.60.56
Re: 2040 jd oil leak on stering column in reply to franklin smith, 10-29-2012 23:35:20
| Unless you see some of the shims peeling out of the valve itself, I wouldn't take it apart. If you do, make real sure you can get it back together the same. You need to get the right shims to get the right clearances. In the half dozen I have done, I only had to work on one valve. Does it steer ok otherwise? |
| franklin smith
11-01-2012 10:23:51
173.19.12.178
Re: 2040 jd oil leak on stering column in reply to MSD, 10-31-2012 21:36:27
| Yes it stees fine.I just checked with a jd place in Jay Florida (16 miles from me) they estimated about 600 dollars to repair it. |
